2nd layer problem
Darenhu
(@darenhu)
2nd layer problem
Hello,
I've had my MK3s+ for about a month 5 days of printing no problems till yesterday. I had my first print failure and now its repeatable. About half way though the 2nd layer the nozzle lowers slightly and starts to dig into the print. I've done the basic trouble shooting recalibrated XYZ, unplugged and re-plugger the Z axis, cold pull, tried a few different model same results with all. I made a solid test cube and let in print till it fully failed I got two results, at layer 4 the nozzle returned to the correct position either causing the print to fail cause it was to high or printing a perfect layer and finishing the print with no issues. I can't figure this one out, there's definitely more testing I need to do but its getting frustrating recalibrating and troubleshoot with the same results.
Thanks for reading,
Daren
Publié : 04/04/2023 7:52 am
RE: 2nd layer problem
With a one month old printer I would get on the chat with Prusa Support as it's still under warranty. Chat is available from Prusa3d.com once you've logged in. They're 24x7.
Publié : 04/04/2023 11:30 am
