.STL file becomes miniature size upon import (PrusaControl or Slic3r)
Paddy
(@paddy)
Been having great success designing models in Fusion360; slicing and encoding with PrusaControl, to make some very nice results. Lately I've experienced this problem, after inserting a model file (.stl) onto the bed (in the program). The file shows up in micro scale.. I mean TINY.
I found re-scaling by 2500% brings the model to the 100% dimensions it was supposed to be. Does anyone have a resolution to this/Are you having the same problem? Trying Slic3r returns same result.
Thanks!
Opublikowany : 02/11/2018 10:17 pm
Re: .STL file becomes miniature size upon import (PrusaControl or Slic3r)
You need to set Fusion 360 to use metric mm units when exporting to STL. Lars has a video on YouTube that shows how. The correction from inches to mm is X 25.4. More here.
Or you are making prints for ants.
Opublikowany : 02/11/2018 10:41 pm
1 ludzie polubili
Paddy
(@paddy)
That worked perfectly! Mades some sense of my math; your saying 25.4 times larger equated to my scaling by 2500%... 2540 then, would have been right on; but there's no need to scale now that I have your conversion reminder!!
many thanks.
Opublikowany : 04/11/2018 8:43 pm
1 ludzie polubili
Ryan Kratz
(@ryan-kratz)
Is there no way to have Slic3r import a model in inches so you don't have to scale each part by 2540%?
Opublikowany : 17/04/2019 5:26 am
JMcK
 JMcK
(@jmck)
I’m pretty sure there are no units in STL files, so it wouldn’t have anything to clue it in that it should convert. Best they could do is add a “Murica” button that was essentially a hard coded “scale 2540%’
For me, I just started modeling in mm and haven’t really looked back.
When someone asks you if you're a god, you say, "YES!"
Opublikowany : 18/04/2019 12:37 pm
