Z bracing yes or no?
stephen.h14
(@stephen-h14)
Like the title says, is there any benefit to adding Z braces to a MK3S? I haven't started assembling my second kit yet so now would be the time to slip in any needed tee nuts to attach bracing or whatever. I searched on here and the interwebs, didn't really find a conclusive back to back test with and without bracing. So what's the thinking? Should I worry about it or not? I am planning to put this second one in an enclosure with the electronics outside so I believe I need to at least add a brace where the PSU would have been. My question is more geared towards the long metal rods some people add though.
TIA
Stephen
Postato : 13/07/2019 12:44 am
RE: Z bracing yes or no?
I've personally never experienced a need for any additional bracing. I even keep my filament spool mounted on the frame.
Postato : 13/07/2019 11:52 pm
Julian
(@julian-4)
This is unnecessary IMHO. I think the prusa z is rock solid. Dont make things more complicated than you have to.
Postato : 16/07/2019 8:09 am
stephen.h14
(@stephen-h14)
Yeah, given the lack of enthusiastic responses in favor of adding the Z braces I decided to leave them off. I'm just adding some printed tee nuts to attach screw on feet and I'm going to try these on the bottom:
https://www.homedepot.com/p/3M-Scotch-1-5-in-Brown-Round-Hard-Surface-Gripping-Pads-8-Pack-SP940-NA/300756418
I used Sorbothane hemispheres on my first MK3 and sat it on a 16" square concrete paver. Appeared to reduce the vertical lines in the print but the Sorbothane is a little pricey. The feet that came with the first printer kept coming out if I had to move it. If the 3M gripping pads don't work out I can always add the Sorbothane to this printer later. Need to pick up another paver too!
Postato : 16/07/2019 3:19 pm
