Y axis shifting
SabreSharp
(@sabresharp)
RE: Y axis shifting
Check your grub screws on the motor pully. If it’s loose they pully can move on the shaft which will give issues like that.
Posted : 09/02/2020 11:12 am
SabreSharp
(@sabresharp)
RE: Y axis shifting
Thank you neophyl that seemed to have fixed the problem.  I also noticed the right side U bracket holding the bearing under the heat bed was also a little loose and tightened it as well.
Posted : 10/02/2020 12:47 am
rmm200
(@rmm200)
RE: Y axis shifting
Be careful with those U Bolts, also known as the Bolts of Death.
Tighten them a bit too tight and they crush the bearing, resulting in binding and calibration failures.
Just snug is enough.
Thingiverse has some bearing mounts that do a better job.
Posted : 10/02/2020 2:56 am
