Y-Axis Shift (and then back again!) during print
useruser55
(@useruser55)
2 times this has happened, see the photo which describes it better than words.   Does anyone have any troubleshooting advice?
ASA Prusament Material with Prusa-standard temps, printing in an enclosure 35-36C, 20% RH.  MK3S with 6 days printing time.
TIA!
Y Axis shift on 2 different prints
Napsal : 24/09/2020 3:08 pm
Area51
(@area51)
RE: Y-Axis Shift (and then back again!) during print
Looks like a loose grub screw on the motor belt pulley. Alternative it could be the belt skipping a tooth and back again.
Napsal : 24/09/2020 5:24 pm
1 lidem se líbí
Posted by: @sbsbsbuser
TIA!
Hello and welcome to the Prusaforum!
Take a look at these pages: https://help.prusa3d.com/en/article/layer-shifting_2020
good luck!
Napsal : 24/09/2020 9:17 pm
1 lidem se líbí
useruser55
(@useruser55)
Thank you for the replies, I've re-installed the Y-axis pulley and refit the grub screws.  Hopefully that was it, it seems intuitively consistent with a shift-then-return behavior.   (belt is clean and tensioned properly, no visible wire issues, etc...)
Thanks again!
Napsal : 25/09/2020 11:23 am
