Y-axis noise
frak.n
(@frak-n)
Y-axis noise
Please see video link below for demonstration of noise:
My new, pre-assembled Prusa MK3S 3d printer maes a rattling noise along the Y-axis. If I hold down the rod on the right side of the bed, the noise goes away (but affects the print) so I think it's due to one of the bearings but I don't know enough to really troubleshoot or fix it.
I tried putting some WD40 on both bearings but no luck/change.
Does anyone have any suggestions?
Opublikowany : 10/04/2019 9:09 pm
vintagepc
(@vintagepc)
Re: Y-axis noise
WD40 is NOT a lubricant.
Follow the instructions here to remove it (yes, you NEED to do that else it will harden/gum up) and re-pack your bearings with grease:
https://prusacommunity.com/set-your-bearing-straight/
Opublikowany : 10/04/2019 9:15 pm
Frank
(@frank-14)
Re: Y-axis noise
I non-silent mode my mk3s (bought as kit a launch) has a similar sound during y movement. I figured out it was the LCD PCB rattling in the 3d printed part. It seems that there's a harmonic resonance. Silent mode fixes. The other option would be to figure out a way to more tightly secure the LCD PCB.
Opublikowany : 12/04/2019 4:38 pm
Chocki
(@chocki)
Re: Y-axis noise
Mine also rattled, a dab of hot melt glue soon put a stop to it! 😀
Opublikowany : 12/04/2019 4:48 pm
