Wrinkles in top layer. How to fix it?
Hi.
I have Prusa i3 MK3S+. My first layers are perfect. But this top layer as you can see has some issues. How to fix it? What could be causing this?
Also there was no warping or print lifting from bed. Print was stuck very good.
Here are images:
I'll be grateful for any help.
This topic was modified 5 years temu 2 times by Hooch
Opublikowany : 13/02/2021 12:50 pm
RE: Wrinkles in top layer. How to fix it?
I think this is normal, because ironing is dedicated to circumvent this very issue. Maybe more top layers will help
Opublikowany : 13/02/2021 3:33 pm
That looks like what can happen when there isn’t enough infill below the top layers.
Opublikowany : 13/02/2021 6:17 pm
Topic starter
answered:
It was 4 solid top layers. 50 percent cubic infill.
Opublikowany : 13/02/2021 6:41 pm
Ok, so not likely that then.
Opublikowany : 13/02/2021 6:53 pm
Hola, did you ever found an issue @hooch?
Opublikowany : 18/12/2023 6:37 am
