Wide print slightly warped - suggestions?
Ira S
(@ira-s)
I printed a case that is about 210x170mm and only about 9mm high (6+ hours).
After I removed it from the printer, I noticed that it wasn't flat. Not the usual lifting on the corners, but the middle of the edges were curved up.
Adhesion to the bed was great - before I removed it, the entire print was flat and fully adhered. Also, I didn't remove it until everything was cooled down (and even if I removed it early, the bending would be in the other direction).
The case is printed flat (NOTE the wavy vertical parts are dead straight - the wave is a camera aberration):
and then hinges into a closed case (no camera aberation here):
Holding the 2 main parts (unassembled) with the base surfaces against each other shows the warp too:
Any insight would be appreciated. Thanks.
Opublikowany : 12/04/2019 4:58 pm
Texy
 Texy
(@texy)
Re: Wide print slightly warped - suggestions?
Ah - PC bed-sheet 😐
Try raising the bed temperature to 70 degree's...
Texy
Opublikowany : 12/04/2019 6:02 pm
