Which parts usually fail?
I have the kit on order. I was curious which parts are usually the first to fail and roughly how long before failure.
Also if these parts are available in the USA like through Amazon or Ebay.
I just want to have some spare pasts on hand when needed, if any.
Thanks
RE: Which parts usually fail?
I'd get at least a couple of thermistors. If you ever want to or have to change the nozzle they're usually the first to break. Add to that a complete hot end assembly (heater block, heat break, heat sink). A couple of heater cartridges. Spare nozzles.
I think the most common printed part to fail is the fan shroud. Un printed, thermistors can fail. On most of my printers, that is all I have had to replace.
Fan shroud, thermistor. Never had a big problem.
Consensus seems to be the fan shroud. Does it just break off from the screw mount? Make one from ABS or PETG?
I bought the black printed parts version. Not sure what material is used.
I will look into getting the nozzles, heater and thermistor.
I have not read in detail, I assume the FW will alert you if thermistor or heater fails?
Thanks
