Which instruction to follow to build the printer?
prusanewuser
(@prusanewuser)
Hi, I have received the printer. It came with Assembly Instructions and 3D Printing Handbook. Both booklets also ask users to refer to the latest pdf download. Which document should I follow to build the printer? I think I also heard that there is a video? Which is the best one to follow? Thanks
Best Answer by holmes4:
I recommend following the online (not PDF) instructions at https://manual.prusa3d.com/ These are not only easier to follow (with enlargeable pictures), but the comments on each step are often very helpful, with tips not mentioned in the instructions themselves.
Respondido : 17/07/2019 12:26 am
holmes4
(@holmes4)
RE: Which instruction to follow to build the printer?
Respondido : 17/07/2019 12:29 am
4 les gusta
prusanewuser
(@prusanewuser)
Thanks. Is it recommended to use a torque wrench during the entire assembly of the printer? Some users reported that setting the wrench to a value of 4.5Nm (suggested in the manual) actually damaged the screw heads. Also, is there a video on the "screw pulling" technique mentioned in Chapter 1?
Respondido : 17/07/2019 1:44 am
I tried a torque screwdriver on the larger frame screws and was very uncomfortable with the spec and the results (~5NM).  Screw heads were deforming, so I backed off and did them by feel. Left the torque tool on the bench after that.  I figured Chinese stainless was adding to the uncertainty.
Esta publicación ha sido modificada el hace 7 years 4 veces por --
Respondido : 17/07/2019 8:57 am
1 les gusta
holmes4
(@holmes4)
I did not use a torque wrench. The screw pulling technique is extremely simple - I'd think a video would be overkill. Though Prusa doesn't suggest it, I have seen elsewhere the suggestion of putting a washer over the screw before inserting into the part to avoid the screw head digging into the plastic. I didn't do that and had no issues, but it is a good idea.
Respondido : 17/07/2019 6:37 pm
1 les gusta
