What is in your toolkit?
Jiheffe
(@jiheffe)
Hi again,
After about two weeks with my new I3 MK3S, I understand I need to gear up a bit for routine mainenance and troubleshooting 🙂 So I was wondering... What do you guys have in your toolkit, besides the tools provided with the kit?
And what spare parts do you need? I see sets of 10 nozzles. Do you often need to replace a nozzle? I also see silicon protections for the heatblock... Is that useful?
I've seen a couple of "maintenance kits" on Amazon, like this one: https://amzn.to/3bSV218. Are these useful? They have three different flavours, V6, MK8, MK10... Looks like I would need the V6, is that correct?
Thnx for your advise!
Veröffentlicht : 22/05/2020 3:38 pm
Xayoz
(@xayoz)
RE: What is in your toolkit?
I keep spare nozzles.  If I need any parts beyond that, I am willing to wait.
As far as tools, I have a small adjustable wrench to hold the heat block when I change a nozzle and a palm ratchet for actually tightening/loosening the nozzle, with sockets for each printer.  V6 is Prusa, MK8 is Creality.
Veröffentlicht : 22/05/2020 4:16 pm
One thing that has been an absolute life saver has been a 150x1.5mm brass rod with smoothed ends. It is invaluable for pushing stuck filament either from the top or bottom of the extruder when I encounter jams. This has saved me many extruder teardowns.
More notes here.
Veröffentlicht : 22/05/2020 5:03 pm
Jimbo70
(@jimbo70)
I have a toothbrush. This is used to wipe the nozzle and to get stray fibers off the print bed.
There are different quality of brushes, the more expensive have very durable bristles that do not melt with the heat.
I suggest your wife's toothbrush - it makes 3D printing more exciting!
Veröffentlicht : 22/05/2020 5:05 pm
Jiheffe
(@jiheffe)
Posted by: @xayoz
Just wondering... Why do you need replace nozzles? Do they wear out? Or do they get obstructed beyond hope?
Veröffentlicht : 22/05/2020 6:32 pm
Jiheffe
(@jiheffe)
Posted by: @louis-j
You like living dangerously 😝
Veröffentlicht : 22/05/2020 6:34 pm
Jiheffe
(@jiheffe)
@bobstro
Thnx for the link to your notes 🙂
Anecdote: while cleaning up her mother house, my wife came across some tools that belonged to her grandfather who was a... dentist... Some small rods that are perfect to remove the dirt around the heater block!
Veröffentlicht : 22/05/2020 6:44 pm
Posted by: @jf
[...] Anecdote: while cleaning up her mother house, my wife came across some tools that belonged to her grandfather who was a... dentist... Some small rods that are perfect to remove the dirt around the heater block!
Ah, great find! Dental picks are great for removing hard-to-reach supports as well.
Veröffentlicht : 22/05/2020 9:09 pm
Mitglied
Here is another good tool kit: AMX3d tool kit
Veröffentlicht : 23/05/2020 8:03 pm
Titan
(@titan-2)
Just my 2 cents worth: I find e3d silicone heat socks work really well with the mk3s and are a great addition for improving print runs. I keep a couple spare brass nozzles (I haven't needed a harder metal nozzle yet), a pair of tweezers for picking any unwanted blobs of filament off the print bed and nozzle, paper towels and a bottle of isopropyl alcohol for more stubborn cleaning jobs.
I use cleaning filament when changing filament material (or just when it feels needed). A pair of small tin snips for preparing filament for feeding into the extruder and I keep a stick of elmers purple glue stick around, just in case I need better adhesion or to protect the surface of the print bed when using very sticky filaments. Also a tube of super lube grease for bearings etc. when necessary (not often).
For everyday basic use that pretty much covers everything I need.
Veröffentlicht : 24/05/2020 8:31 am
Mitglied
Posted by: @nathan-b20
The bronze nozzles will have to be replaced more often with abrasives.  I have found that the Vanadium and Tungsten nozzles last over a year with abrasives.
  1. Tungsten Nozzle
  2. Vanadium Nozzle
Veröffentlicht : 24/05/2020 3:58 pm
Jiheffe
(@jiheffe)
Thank you everyone for your help 🙂
Veröffentlicht : 24/05/2020 5:07 pm
