What causes these lines?
Gavin
(@gavin-4)
What causes the lines in the attached file?
Prusament  Petg 100% infill .6 nozzle.
It's indented by the same amount on the inside, like its a layer shift, but only in that section.
Prusa gcode viewer has it looking perfect without these lines/layer shifts.
Este debate ha sido modificado el hace 3 years 2 veces por Gavin
Respondido : 14/04/2023 3:32 pm
Gavin
(@gavin-4)
The inside
the other side:
Esta publicación ha sido modificada el hace 3 years por Gavin
Respondido : 14/04/2023 4:06 pm
How thick are those walls
Files > Save Project as
Respondido : 14/04/2023 10:02 pm
Gavin
(@gavin-4)
Here's the file. Was only 40kb smaller zipped up so saved people one step.
I am eager to hear if it's a slice or a printer issue as I thought things were working ok on my printer.
Thanks.
Respondido : 15/04/2023 6:17 am
RE: What causes these lines?
The zip is required as the forum only accepts a very limited amount of file types. It has nothing to do with size.
Respondido : 15/04/2023 6:39 am
Gavin
(@gavin-4)
Oh. Here it is then.
Respondido : 15/04/2023 6:52 am
Hello
(@hello)
I would suggest go to 60 percent infill it may or may not make a difference
Respondido : 15/04/2023 9:43 am
Agreed.  100% fill is almost always a mistake, it leaves the slicer no overhead to compensate for minor issues.  The walls are only three extrusions thick, an internal and external outer perimeter and one extrusion between, another very constraining factor.
I don't have a 0.6 nozzle fitted atm so printing here wouldn't tell us anything.  If you can, thicken the walls and reduce the infill.
Respondido : 15/04/2023 6:30 pm
