What are the Original MK3s step settings?
matthew
(@matthew-3)
I have 2 MK3's, one with the bondtech extruder and one brand new MK3s without any mods sofar.
By accident, I sent the step file code for the bondtech to the MK3s , and now the stepper wont work properly. I flashed the firmware, but stilll stuck on bondtech extruder settings.
Does anyone know the extruder step settings for the MK3s?
The bondtech settings are
M92 E830
M500
any help would be great
Thanks
Postato : 23/05/2019 10:51 am
Gabe
 Gabe
(@gabe-3)
RE: What are the Original MK3s step settings?
Did you ever receive an answer for the stock settings?  I did the same thing an I'm stuck.
Postato : 30/06/2019 2:18 am
Holger
(@holger-2)
M92 E280
M500
HF
Postato : 30/06/2019 2:45 am
Gabe
 Gabe
(@gabe-3)
Just copy to notepad and rename as a .gcode, then put on an SD and run it?
Postato : 30/06/2019 3:20 am
Holger
(@holger-2)
Posted by: gmsurges
Yes, this should work^^
M92 E280
M500
Postato : 30/06/2019 5:30 pm
Sembazuru
(@sembazuru)
Posted by: gmsurges
Probably easier to just use a terminal interface like pronterface. Connect pronterface to your printer and type in the commands in the lower right-hand text box
See my (limited) designs on:
Postato : 01/07/2019 2:47 am
