"Watermark" under print
Pobi
 Pobi
(@pobi)
MK3S with PLA
A "watermark" shape has started appearing under my prints:
I'm not seeing anything resembling the shape on the PEI sheet. Does anyone know what this could be due to?
Thanks for the help!
Postato : 02/03/2022 2:56 am
That looks like local poor adhesion, probably a greasy fingermark on the print-sheet.  Time for a wash.
Postato : 02/03/2022 4:47 am
kpreid
(@kpreid)
RE: "Watermark" under print
Yes, the bottom left corner of the print detached. Besides bed cleanliness, this can also be affected by the shape of the print (as printed plastic cools, it shrinks, and this creates forces that pull edges off the bed), and also ambient temperature (cold air means the bed heater is less effective at keeping the plastic above the immediate surface warm).
Besides cleaning, you can also try using a “brim” in the slicer, adding “mouse ears” to your corners, or redesigning your part so it doesn't have sharp corners. Sharp corners that have walls above them have the greatest tendency to lift.
Postato : 02/03/2022 5:43 am
Pobi
 Pobi
(@pobi)
I never considered that it could be an adhesion issue. I'll try those suggestions next time I print a similar shape. Thank you for the tips!
Postato : 02/03/2022 7:18 pm
