Vertical strips when printing thin vertical walls
Hi, when printing vertical wall of 0.5 to 1mm thick, I see some ugly holes or vertical strips on the surface. I thought they were seams but at each layer, the extruder always moved from one end to the other in one stroke. Moreover, there was no seam on the surface in PS. What are the causes and how can I prevent this from happening?
Posted : 03/10/2022 1:05 am
RE: Vertical strips when printing thin vertical walls
You might wanna post a photo and/or your model file.
Posted : 03/10/2022 2:09 am
Print thicker walls. You are in the range of just over one default extrusion width to just over two, there is no room for even Arachne to make a decent job. You should see significant improvement from about 1.3mm upwards.
Posted : 03/10/2022 9:41 am
