twin spool holder
ronnie12342003
(@ronnie12342003)
twin spool holder
hi anyone have the stl for the new twin spool holder shipped with the latest mk3 ?
Veröffentlicht : 06/08/2018 10:43 pm
Dewey79
(@dewey79)
Re: twin spool holder
Where did you see it? The only twin spool holder I've seen and I don't have one is on the MK2 models.
Veröffentlicht : 06/08/2018 11:17 pm
RufusClupea
(@rufusclupea)
The dual spool holder is not printed; it is injection molded.
There may be something on Github--I don't know--but there are several dual spoolholder designs on Thingiverse.
That's "MISTER Old Fart" to you!
Veröffentlicht : 06/08/2018 11:22 pm
Dewey79
(@dewey79)
I was considering them myself ever since I got my MK3, but with the suspicions that one, now two spools would/could cause vibration I opted to forget it. If things go well I'll be mounting it above and behind the printer.
Veröffentlicht : 06/08/2018 11:28 pm
RufusClupea
(@rufusclupea)
Good plan. 😉
Can you imagine someone trying to mount 5 spools up there, along with the MMU2? 😆
Veröffentlicht : 06/08/2018 11:32 pm
I mirrored the single filament holder along the X axis, so I can mount two holders in the centre of the top frame, with the handles facing out... to mount two rolls on one printer....
Veröffentlicht : 07/08/2018 1:00 am
ronnie12342003
(@ronnie12342003)
thanks joan will do that
Veröffentlicht : 07/08/2018 1:05 pm
Hi Peter, should look a bit like this!
the one on the right is the mirrored one
Veröffentlicht : 07/08/2018 2:24 pm
dumbcomputers
(@dumbcomputers)
The new injected molded dual holder does not "clip" on very well. With the weight of the filament on it holds it in place but if pushed forward it falls off. I prefer the updated 3D printed version more.
Veröffentlicht : 07/08/2018 4:54 pm
ronnie12342003
(@ronnie12342003)
all fitted now I feel the extra weight of the other spool helps absorb any vibrations after all you are only using one spool at a time well done joan atb pete
Veröffentlicht : 07/08/2018 9:58 pm
muddymaker
(@muddymaker)
Mine is as tight as a 70s disco dancers leather pants, Just the way I like it 😳
Veröffentlicht : 08/08/2018 7:13 am
