To e-step calibrate or not?
Gato
 Gato
(@gato)
As expected, you will find conflicting information on the internet. 😥
Reading about extruder calibration in general, I see that there are 2 things to do: 1. Steps calibration and 2. Multiplier calibration. However, I also found information on this forum and on bondtech site http://www.bondtech.se/en/faq/ that says that these/our gears use a fix value for steps and should not be changed. I guess that the firmware and Prusa did their math to tune the number. But then again I see in this forum and on FB that some people are still doing the steps calibration.
So what is the official answer? I never saw something coming from Prusa folks so not sure what to follow. As I receive my printer kit this week, I was going to measure the steps vs filament and hope they match. But if they don’t then what? What did you guys/gals do?
Thanks
Gaston
Postato : 30/04/2018 7:33 am
1 persone hanno apprezzato
GertL
(@gertl)
Re: To e-step calibrate or not?
I used to do this but now since my 2.5 upgrade i tweak it in the slicer.
To messy to e-step calibrate for each and every filament.
Gert
Postato : 30/04/2018 9:00 am
Bigdogbro1
(@bigdogbro1)
I have never E-step calibrated my MK3, I feel it's a relative setting so I just adjust the extrusion multiplier for what works best with each filament (and sometimes even color) and print layer thickness. Right or wrong it works fine for me.
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Postato : 30/04/2018 1:27 pm
Kwaad2
(@kwaad2)
1mm =1mm
1mm = 280 microsteps
It honestly makes no difference, as mechinacally, 1 step is 1 step.
I just Adjust extrusion multiplier in my slicer.
Getting it prefect is the challenge.
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Postato : 30/04/2018 4:14 pm
Crunch
(@crunch)
Thanks
Gaston
I did both and it is noticeable better than stock my steps where off 1mm and my multiplier was off.01mm
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Postato : 06/05/2018 9:48 pm
GertL
(@gertl)
I calibrated the teh steps on my MK2S, moving to MK2.5 i have not.
The difference between filaments and even colors from the same brand make you need to tweek the extrusion multiplier in the slicer anyway.
Just my 2 cent.
Gert
Postato : 07/05/2018 9:13 am
