Technical Support Chat
Bobby Phillips
(@bobby-phillips)
I have been very happy with my Prusa. That being said, I'm a little surprised at the quality of the technical support chat. It's been over a week ago with my first tech support chat. I had a print cooling fan go bad on my MK3. Tech said he would send one out right away. The shipping was actually very prompt and I had a fan within five days. However, it was the fan for the MK2. I contacted tech support again and they said they would ship out the correct fan. Three days later, no confirmation that anything has been shipped. In the meantime, my y-axis pulley has gone bad. It is creaking and popping extremely loud. I swapped to the x-axis to verify it was the pulley... it was. I contacted tech support again to 1) check on my fan and 2) discuss the pulley issue. Here is a snippet of the transcript:
Bobby Phillips 07:42:03 am
Ok.. to summarize.. it's been almost a week with no help. I have a defective part cooling fan, Prusa sent the wrong one, I'm still waiting for notification of the correct one being shipped. Also, I have a Y-axis idler pulley that has gone bad and need it replaced.
Martin 07:42:20 am
OK, minute
Y-axis what do you mean?
Bobby Phillips 07:43:15 am
The belt that moves the bed back and forth... on the Y-axis. The pulley installed at the front of the printer has gone bad.
Martin 07:43:24 am
The pulley is loose ok?
Bobby Phillips 07:44:12 am
No it's not loose. The install is good, the printer returns good values for the belt tension. The bearings have gone bad. It makes a grinding noise and pops very loudly.
Those videos demonstrate the issue.
It shocks me that the chat tech did not know what I meant by "Y-axis!!"
That was Friday morning (probably 1-2 in the afternoon in Prague). I've yet to see a DHL shipment notification.
Very disappointed in the quality and responsiveness of the tech support.
And by the way, I've also sent 2 e-mails to [email protected] and in a week's time, there has been absolutely NO response.
Veröffentlicht : 28/04/2018 5:43 pm
Kwaad2
(@kwaad2)
Re: Technical Support Chat
Edit: Wait, there's a bearing on that? I totally didn't know that.
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Veröffentlicht : 28/04/2018 8:01 pm
Crunch
(@crunch)
I have had the same experience that went on for over 30 days and I think I chatted with every support person on staff trying to resolve what ended up being a warped heat bed and extrusions that where not cut square causing the frame to rock.
My personal experience if it is a hardware mechanical issue there is only one person that can resolve problems and his name is Shane
If its a MK3 firmware problem you need to post on github as the staff on chat do not appear to have a working knowledge in that area.
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Veröffentlicht : 28/04/2018 8:50 pm
Kai
 Kai
(@kai-2)
+1 for Shane
He provides an excellent support!
nec aspera terrent
Veröffentlicht : 30/04/2018 9:48 am
michael.a35
(@michael-a35)
+10 for Shane.
Veröffentlicht : 30/04/2018 10:14 am
