SunLu PETG settings
Agkirk
(@agkirk)
SunLu PETG settings
I have have been setting my temps for the subject filament to first layer 240/85 and second layer+ 250/90 to get good adhesion.  SunLu box says to use a range of 190-220.
Anyone else experience this higher temp?
Napsal : 22/10/2020 8:40 pm
Romio
(@romio)
RE: SunLu PETG settings
I use the generic PETG settings for Sunlu. Works for me.
Napsal : 11/11/2020 6:16 pm
Chocki
(@chocki)
I use SUNLU PETG at a print temperature of 215 Dec, First layer 80 bed then 85 for the rest.
The biggest improvement has been to only have a fan speed of 16, yes 16, any lower and it stalls and keep your printing speed down.
With this I get really good strong prints which adhere very well.
Napsal : 15/11/2020 4:33 pm
Wardyl25
(@wardyl25)
Are you guys using the textured bed for your prints?
Napsal : 19/03/2021 6:17 pm
Posted by: @agkirk
Yes.
Napsal : 19/03/2021 8:34 pm
Romio
(@romio)
@wardyl25
yes but also the smooth one.
Napsal : 20/03/2021 1:38 pm
sca
 sca
(@sca)
Posted by: @agkirk
Perhaps you have the wrong box?  The temperature range you mention matches their PVA recommendation.  SunLu claims their PETG needs 220-250/70-80:
 https://forum.sunlu.com/viewtopic.php?f=31&t=165
-Scott
Napsal : 20/03/2021 3:08 pm
@sca
That is a good point - or the wrong filament in the box.  It is not unheard of.
Napsal : 21/03/2021 6:05 pm
androx
(@androx)
My 2 cents. Starting printing with SUNLU PETG, I followed some indication in this thread.
But I have to admit that the best settings for my MK3S+ are the same of Prusament PETG.
Napsal : 07/05/2021 9:15 am
@androx
Similar values for me.  I started at Sunlu PETG and had less than ideal results and then tried Prusament PETG and adjusted from there,
Napsal : 07/05/2021 9:38 am
androx
(@androx)
@cwbullet
thank you for the feedback.
I only had to change a little the Live Z (smaller value - major distance). I don't know if this is a normal thing to do when you change the filament brand.
Napsal : 07/05/2021 9:41 am
@androx
Live Z change can be common with some filament brands.
Napsal : 07/05/2021 10:34 am
DaniAngel
(@daniangel)
Posted by: @agkirk
Yes I have noticed this as well.  So much so that I was searching for information on SunLu PETG and that is how I found your post.  I also notice that it depends on the color of SunLu PETG as well.  The green and blue I print at 238 C.  The white and black Sunlu PETG take a much higher temp.  I am printing white at 247C and black at 250 C.  It's very frustrating that their recommended temps are not even close to producing good results.
Napsal : 28/02/2023 9:15 pm
