Stress relief on X ends
gregsaun
(@gregsaun)
Hi all,
What's the idea behind the "stress reliefs" on the x ends? Does it really absorb some stress on the X axis? It looks useless on x-end-motor then, no?
Bear Upgrade Frame for Prusa
--- thingiverse.com/pekcitron --- patreon.com/gregsaun --- ekunn.com
Postato : 12/04/2018 10:22 pm
Sendeva
(@sendeva)
Re: Stress relief on X ends
It is how its been made in Openscad they use the same asset of both parts this way when they make a change to the shared asset it applies to both parts.
Does it need to be on the stepper side no, Does it affect the function of the part no, So why spend the time making a separate asset just for that one part when you can use a shared asset.
On the pully side its there to give some play when you over tighen the screw so you dont brake the part.
Postato : 12/04/2018 10:39 pm
gregsaun
(@gregsaun)
Oh that's for the tightening of the screws, understand now! Thanks 😉
I read the OpenSCAD files and know that they share x-end.scad, but I am going to do my mod on Fusion 360
Postato : 13/04/2018 12:28 pm
m2tts
(@m2tts)
How are you bringing the OpenScad models into Fusion? OpenScad is polygon based and Fusion is nurbs.
Postato : 14/04/2018 1:56 am
gregsaun
(@gregsaun)
I read the code and re-draw everything from scratch, much flexible to add improvements
Postato : 14/04/2018 11:32 am
gregsaun
(@gregsaun)
Work ongoing on the X ends and extruder for MK2.5/MK3 :
More details on this FB group : https://www.facebook.com/groups/prusabearupgrade/
Postato : 14/04/2018 11:35 am
