steel sheet delaminating when printing w/PC Blend
Dustin
(@dustin)
I just started printing with the Prusament PC blend, haven't had great luck though, typical edge warping so I need to work that out.  The bigger issue I noticed though is slight delamination on the steel sheet in the area where the warping occurred.  Is that normal?  Am I using the wrong sheet?
Respondido : 26/01/2021 1:01 am
Miembro
RE: steel sheet delaminating when printing w/PC Blend
Are you using the glue stick and waiting for it to cool to remove?
Respondido : 26/01/2021 2:56 am
Dustin
(@dustin)
@cwbullet
Yeah, I did quite a bit of reading prior to using PC and no one mentioned this issue.  I actually didn’t notice the issue until I went to wash the sheet.
The interesting thing is the only area that seems to be separating is the same area that has warping.
Respondido : 26/01/2021 3:01 am
Miembro
@dustin-7
The warping is why you need the glue stick.  I have found less wrapping with smaller prints in a heated enclosure.
Respondido : 26/01/2021 3:04 am
Dustin
(@dustin)
the print I’m having issues with has three separate parts, I’ll separate them into individual prints.
the printer is right near the house boiler so I feel like it’s plenty warm in that utility room.
I’ll order a new sheet per your recommendation in the other thread and see what happens.
Respondido : 26/01/2021 3:08 am
Miembro
I print with my enclosure at 100 F or 37.7 C.  That has reduced the warping. I also only print small parts with PC Blend.
Respondido : 26/01/2021 3:31 am
