Squished edge corners on ASA calibration cube print
Wayne
(@wayne-9)
Membre
I'm trying to print the calibration cube from https://help.prusa3d.com/article/extrusion-multiplier-calibration_2257 and the back corners are not straight lines.
They seem squished - I'm not sure if this is a warping issue or something else?
I'm using Prusament ASA sliced in Prusa Slicer using the default settings for the filament (bed: 260, tool: 105), and the 0.20mm quality profile. I also tried changing fan speed to 10% with the same outcome.
I'm printing in a prusa original enclosure that I've let get up to 30C before starting the print, and I'm printing onto the textured plate, and I've run PID tuning at 260C
Any advice would be great thanks!
Ce sujet a été modifié il y a 2 years par Wayne
Publié : 26/11/2023 12:41 pm
