Software failure after filament change
cashbaugh
(@cashbaugh)
Filament ran out so I swapped in new filament according to the prompts.  Printer came back to life and resumed printing for about 5 seconds, then stopped and reset itself (16 hrs into a 24 hr print).  I cleared the work surface facing a restart but now the whole printer doesn't work - the rotary switch no longer moves through the dialogue and the sd card is not acknowledged.  I've shut down and restarted several times.
Thoughts?  Firmware v: (can't tell - that screen is no longer accessible)
When I insert the sd card, I just get little circles, then a prompt for "<back"
Opublikowany : 22/02/2021 3:23 pm
cashbaugh
(@cashbaugh)
RE: Software failure after filament change
Also - I've tried a factory reset - still, the rotary switch does not scroll through the dialogue.
Opublikowany : 22/02/2021 3:31 pm
