Slicer settings for sample Gcode?
Mak
 Mak
(@mak)
I'm trying to do a bit of investigation at the moment on various parameters, and I want to start from a known "perfect" print. The sample gcode for Benchy on my Mk3 is immaculate, and what I'd like to do is vary things from that starting point. Just one problem...
I have no idea what configuration was used to slice that gcode by Prusa. Can anyone help please?
Cheers.
Postato : 26/07/2019 8:48 pm
RE: Slicer settings for sample Gcode?
Posted by: rick.j5
[...] I have no idea what configuration was used to slice that gcode by Prusa. Can anyone help please?
Open the gcode in a text editor and you can see the settings. Assuming it was sliced with PrusaSlicer/Slic3r, the settings should be included. Depending on the version used and that you're running, you can try opening it as a config file. This normally works well, but recent version and program name changes have made it less than reliable.
Postato : 26/07/2019 9:11 pm
Mak
 Mak
(@mak)
Perfect, thanks.
Postato : 26/07/2019 9:12 pm
Worst case, you can edit the text file to strip the gcode and remove the semicolons at the start of the PrusaSlicer parameters, then save it out as a config file.
Postato : 26/07/2019 9:14 pm
