Slic3r settings location
TheQuestor
(@thequestor)
When I start Slic3r, I get a message:
Cannot create configuration directories: boost::filesystem::create_directory: The system cannot find the path specified:
"C:\Users\Public\Documents\Prusa3D\Slic3r settings MK3 216"
Does anyone know where the configuration file is located so I can edit it manually? There is no such directory on my computer, and it should be pointing elsewhere.
Postato : 23/06/2018 2:41 am
ron-f
(@ron-f)
Re: Slic3r settings location
Now it is there
Windows: "C:\Users\your_user_name\AppData\Roaming\Slic3rPE" or "C:\Documents and Settings\your_user_name\Application Data\Slic3rPE"
Postato : 23/06/2018 3:36 am
TheQuestor
(@thequestor)
There's no such folder under Roaming.
Postato : 23/06/2018 4:20 am
TheQuestor
(@thequestor)
I just created the missing directory; now I think I can move it... thanks!
Postato : 23/06/2018 5:35 am
ron-f
(@ron-f)
You can also use a directory of your own by running (launched quickly with a shortcut):
path_to_slicer_exe\slic3r.exe --DataDir "your_settings_directory"
It is what I use. Then I can still run older releases without too much issues as I run older releases with their own directory.
Postato : 26/06/2018 3:48 pm
