Slic3r Prusa Edition 1.42.0-alpha7
Página 2 / 2
Protoncek
(@protoncek)
Re: Slic3r Prusa Edition 1.42.0-alpha7
Thank you both (Michael and you) for explanation. I did try, but i really couldn't figure it out. I don't have MMU unit, and also i didn't try models with "hanging" parts, so at the end both clicks ended up pretty much the same. I did notice that parts are moving together while objects are moving separately, but i really couldn't conclude why this would be usefull...
So, basically, until i get myself an MMU unit (it WILL come one lucky day - i hope...) "objects" is the thing for me...
Respondido : 12/03/2019 7:33 pm
sbellon
(@sbellon)
Any comment on the regression I reported in this thread (post #10)?
Respondido : 13/03/2019 7:23 am
tadas.s
(@tadas-s)
iS NOT WORKINING PROPOLY
Respondido : 13/03/2019 10:37 pm
Protoncek
(@protoncek)
First of all THERE'S NO NEED TO SHOUT! writing with capitals means that you're shouting! WHY?
Second, noone will help you with so useless comment. WHAT doesn't work properly?
Respondido : 15/03/2019 11:29 am
Dash
 Dash
(@dash)
I am having a problem with the new updates. I am not sure if this is where I need to post it at but I will start here.
With the new updates 3.6.0 firmware the 1.0.5 MMU2 update and the SlicEr PE 1.41.3 update I am getting duplicate extruder selection T-codes at the start of the program, which causes the printer to stall with a message of "Duplicit T-code ignored".
I can fix the code by editing the second extruder call out of the code but I really would like to not have to. 😉
This is the start of the code-
; generated by Slic3r Prusa Edition 1.41.3+win64 on 2019-03-16 at 22:20:15
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.42mm
M73 P0 R304
M73 Q0 S307
M201 X1000 Y1000 Z1000 E8000 ; sets maximum accelerations, mm/sec^2
M203 X200 Y200 Z12 E120 ; sets maximum feedrates, mm/sec
M204 P1250 R1250 T1250 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z0.40 E1.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
M107
M115 U3.6.0 ; tell printer latest fw version
M83 ; extruder relative mode
M104 S230 ; set extruder temp
M140 S85 ; set bed temp
M190 S85 ; wait for bed temp
M109 S230 ; wait for extruder temp
G80 ; mesh bed leveling
G21 ; set units to millimeters
; Send the filament type to the MMU2.0 unit.
; E stands for extruder number, F stands for filament type (0: default; 1:flex; 2: PVA)
M403 E0 F0
M403 E1 F0
M403 E2 F0
M403 E3 F0
M403 E4 F1
;go outside print area
G1 Y-3.0 F1000.0
G1 Z0.4 F1000.0
; select extruder
T3 ; This selection works fine
; initial load
G1 X55.0 E32.0 F1073.0
M73 Q0 S307
M73 P0 R304
G1 X5.0 E32.0 F1800.0
G1 X55.0 E8.0 F2000.0
G1 Z0.3 F1000.0
G92 E0.0
G1 X240.0 E25.0 F2200.0
G1 Y-2.0 F1000.0
G1 X55.0 E25 F1400.0
G1 Z0.20 F1000.0
G1 X5.0 E4.0 F1000.0
G92 E0.0
M221 S95
M83 ; use relative distances for extrusion
G92 E0.0
;T3 (this selection causes the printer to halt) with a message of duplicit T-code ignored
M900 K45 ; Filament gcode
G1 Z0.200 F10800.000
;BEFORE_LAYER_CHANGE
G92 E0.0
;0.2
Thanks in advance
Respondido : 17/03/2019 3:52 am
Vojtěch Bubník
(@vojtech-bubnik)
Miembro Admin
This is the same case as https://github.com/prusa3d/slic3r/issues/1920
Fixed with https://github.com/prusa3d/Slic3r/commit/c4829338453691371fc089d0aaf2cb9271417415
It will be part of the upcoming beta
Respondido : 17/03/2019 8:58 am
sbellon
(@sbellon)
@bubnikv: Thanks a lot. Looking forward to the upcoming beta!
Respondido : 17/03/2019 12:15 pm
Sembazuru
(@sembazuru)
Unfortunately, the beta seems to be broken. Please see my bug report on github:
https://github.com/prusa3d/Slic3r/issues/1978
See my (limited) designs on:
Respondido : 18/03/2019 7:49 am
Mustrum Ridcully
(@mustrum-ridcully-2)
The mac version seems to be ok but I forgot to grab a set of the Alpha7 .ini files as I had become used to them coming along automaticly with each new alpha, and now I have to reconstruct them from scratch as the beta has just the Prusa provided .ini file that its configuration assistant sets up.
so be sure to save a set of your alpha .ini files before you move to the beta
Respondido : 18/03/2019 5:44 pm
Sembazuru
(@sembazuru)
I don't know how the settings work on MacOS, but on Windows the beta created a new settings folder along side of the stable and alpha settings folder (in appdata\roaming). So, you can actually have the previous stable, one of the alphas, and the beta all installed and running side by side. Try reinstalling alpha 7 to see if the settings are still there. Save out your settings bundle. Fire up the beta and import the settings bundle. I did see a bug report of someone why tried copying their alpha settings into the beta settings folder and Slic3r choked, but the beta seems to load the settings bundle exported by the alpha ok. (Unless that is the root of my problem...) 😉
Respondido : 18/03/2019 11:04 pm
Dash
 Dash
(@dash)
Sorry my post was in the wrong place. I am not sure how I navigated to this thread and posted my apologies.
Respondido : 19/03/2019 12:26 am
Sembazuru
(@sembazuru)
For others watching, I just saw on github that this issue is resolved and will be in the next release (next beta?) I'm not sure what caused the issue, but what ever I did caused a divide by zero error... Trust me to try to break the rules of mathematics.
Respondido : 19/03/2019 4:15 am
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
UPDATE: New version is here. Check out our newest beta build
Assembly manuals
/ Knowledge Base
Respondido : 19/03/2019 7:35 pm
Mustrum Ridcully
Thanks this worked just as you outline above....
Respondido : 20/03/2019 10:02 pm
Página 2 / 2
