Slic3r PE 1.39.2-beta
Update: there is a new version of Slic3r PE, more here https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64/drivers-2-1-5-with-slic3r-pe-1-39-2-t17762.html
Josef just announced latest build of Slic3r PE 1.39.2-beta, which should solve the inconsistent extrusion issue some people had. It also has updated print settings built in.
To test it out, copy it to your computer and run configuration wizard. It will not affect your regular Slic3r and it’s settings from Windows drivers.
Note, this isn't a stable version and it is recommended for testing purposes.
Download: https://github.com/prusa3d/Slic3r/releases/tag/version_1.39.2-beta
Looking forward to your feedback 😉
Re: Slic3r PE 1.39.2-beta
Hi Jakub -
You mentioned this new 1.39.2 beta has new settings built in. When I first installed it, it had travel speed at 250 mm/s, infill at 200 mm/s. I then ran the Configuration Wizard to ensure I had proper values, selecting MK3 and checking the box to reset profiles from scratch. Now my speeds are back to the 170 mm/s for both travel and infill that I had before. Which is correct? Which are the latest values? Maybe settings got updated for initial installation, but the Configuration Wizard they forgot to change?
Thanks,
Austin
Hi Austin,
the 170 mm/s is correct value for MK3, just confirmed with my colleague and with GitHub.
Hi Austin,
Thank you so much for the response. Trying out Slic3r 1.39.2 beta and the new MK3 3.2.0 RC2 firmware now!
That's the spirit! 😎
The release notes only mention it was caused by slowdown on short layers.. when this happens on every layer no matter how large the print.. so I fail to see how this addresses the issue at all.
printing a 40mm test cube now, will post a pic after, my speeds say 170mm/s as well. have you guys tested any simplify3d profiles tuned for the mk3 recently?
edit: after a vase mode 40mm cube print, i got this as a result. im running 3.2.0RC1 in my mk3.
Looks like no improvement to me.
Have a look at the release notes, as far as I understand the new procedure can't really help in vase mode (the idea of slowing down infill and inner perimeters enough to be able to print the external perimeter at it's normal speed does only work if there actually are other features than external perimeters. That's not the case in vase mode)
Hasn't improved anything for me, both my mk3's print worse than my mk2 still.
Hi mark.w2,
Have you tried a Factory Reset (section 7.2.6 in the latest manual)? If you try this, reset "All Data". You will have to run throught the complete hardware setup routine, but this shouldn't take more than 30 minutes. This completely transformed my machine, and is now printing really well, dare I say it better than my MK2S.
Cheers,
Dave Jackson
Cheers,Dave Jackson"Enthralled Nooby (not so much maybe, ~58 years old)... If 3d printers had been around 40 years ago... "
I’ll give that a go, thanks for the suggestion
Printers are idle anyway, so nothing to lose
I can't get ColorPrint to work with this build. I'm using the layer color change feature. Rolling back to the current release allowed Color Print to work correctly again.
