Slic3r 1.41.0-alpha2 print time estimation display issue
Haku3D
(@haku3d)
The "Estimated printing time" numbers don't update properly.
If you load up a .stl, slice & save .gcode you get the "Estimated printing time" numbers showing, but if you then select the object and press '+' to make 2 or more copies then slice & save .gcode, the "Estimated printing time" numbers don't get refreshed to show what they're supposed to be.
Napsal : 26/07/2018 9:34 pm
Re: Slic3r 1.41.0-alpha2 print time estimation display issue
Hi Ridwan
I am using Slic3r v1.40.1 +win64
with one small model the projected time is just over 16 minutes, and
with two small models, the projected time i just over 32 minutes
I wonder what's changed?
Napsal : 27/07/2018 11:54 am
Haku3D
(@haku3d)
hi Joan,
I found with this Slic3rPE-1.41.0-alpha2+win64-full-201807211541.zip version I'm running, after doing a slice+gcode save, subsequent increasing/decreasing model copies doesn't update the print time estimation after slicing+gcode saving, I have to load or delete an additional model and then print time estimation numbers will show properly after slicing+gcode saving.
In the summary for 1.41.0-alpha2 they do say they've been working on the print time estimation code to also give an estimation in stealth mode, maybe this is where the bug crept in.
A little annoying but doesn't stop me printing, I guess this is why it's an alpha version 🙂
Napsal : 27/07/2018 6:22 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Somebody reported the bug and it will be fixed in the upcoming beta.
https://github.com/prusa3d/Slic3r/issues/1081
Napsal : 02/08/2018 6:39 pm
