Shape cut out tool
garethsnaim
(@garethsnaim)
Shape cut out tool
Am I going insane?
For a period of time I was able to add a shape in slicer that would cut that shape out of my model, I did it with some tubes to create holes and it worked perfectly.
I am on 2.7.1 and see no evidence of this tool.
I am sure I did not imagine it...
Veröffentlicht : 08/01/2024 2:09 pm
vhubbard
(@vhubbard)
RE: Shape cut out tool
Select the object your want to use the negative volume on in the right menu list.   Right mouse button to pull up a list of actions, select the "Add Negative Volume" and then upload one or select the type of volume.  Position and scale as needed.   The negative volume becomes a child of the part.
Some things about Negative/cut volumes.
Negative volumes cannot be used to remove something outside of the print area.  If  part falls outside the print volume it will not slice.   It is an enhancement to allow slicing if negative volumes remove what is outside the print boundary,  not a bug according to support.
Being able to save a .stl with the negative volume removed is still a work in progress.   It saves the .stl with merged/added volumes but does not always save the negative volume result in many cases for me.
Veröffentlicht : 08/01/2024 2:44 pm
srmalloy
(@srmalloy)
Mitglied
I ran into this myself today; I had an STL that I added an SVG to as negative volume, and was able to save it with the incised SVG, but the SVG logo was too thin, and when I widened the lines on the image used to make the SVG and repeated the process on the 'blank' STL, Prusaslicer refused to save the negative volume with the base object. I tried several different ways to do it, and finally gave up and saved the STL as a 3MF.
Veröffentlicht : 27/08/2025 2:22 am
