Settings for TPU
I want to print with TPU but I can’t find the settings on prusa control slicer. Anyone can help? I want use with prusa control
Napsal : 08/07/2018 3:02 pm
Re: Settings for TPU
I've looked through the most recent PrusaControl and don't see any flexible or similar materials. You're probably better off using Slic3r for flexibles for now.
Napsal : 08/07/2018 7:12 pm
As a starting point, use Slic3r and modify the generic PLA profile to tweak the temperature and limit the volumetric flow rate to around 5 mm^3/sec.
You will probably have to experiment with it a bit because TPUs vary quite a lot. The main thing is the flow rate limitation. The harder the TPU you're using, the higher the flow rate you can use.
Napsal : 12/07/2018 8:01 pm
