Set print speed
brett.i
(@brett-i)
Set print speed
Is there an easy way to set print speed BEFORE printing either via the control panel or in Slic3r? I know you can set the print speed on the control panel AFTER the print has started, but is there a place to set it before? I know speed settings can be individually set within Slic3r also...I was just curious if there is an easier way to slow the whole print operation down below 100% for very tiny detailed parts for example. Thanks in advance!
Veröffentlicht : 31/08/2018 10:21 pm
OPK
 OPK
(@opk)
Re: Set print speed
SlicerPE - Printer settings - Speed
Veröffentlicht : 03/09/2018 12:15 pm
Area51
(@area51)
Mitglied
Re: Set print speed
M220 Set speed factor override percentage.
Exmaple:
M220 Sxxx -sets speed factor
M220 Sxxx B -backups current speed factor and then sets new speed factor
M220 B -just backups current speed factor
M220 R -restore saved speed factor
You can use M220 in your gcode to change speed override.
I think you have to edit the gcode after generation as I see no way to get Slic3r to do it for you, except in start gcode.
Veröffentlicht : 03/09/2018 12:26 pm
