Prometheus hot end in a MK 3?
Mustrum Ridcully
(@mustrum-ridcully-2)
https://www.facebook.com/groups/prusacommunity/permalink/890891674584899/
I found this at a yard sale markings on the box indicate that it is about 3 years old: all the parts seem to be here has anyone tried this hot end in a Prusa MK3 and if so how has it worked out? my thought was to make up an extra hot end to be swapped when the SS nozzles would be handy for things like abrasive or high temperature plastics
a search here on the keyword Prometheus generated no hits.
it says it is 12/24 volt I thought a special 24 volt heater cartridge was needed fo the MK3
are any modifications to the extruder carriage assembly needed and are set STLs available ? the difference in the contents of the kit from the standard instructions is the addition of 2 extra nozzles 0.3 and 0.6mm
anything to watch out for? if not a good fit for the MK3 I might build it for my Rostock max V2.5 delta as it seems to be lighter than an e3dv6.
Prometheus Hot End
TABLE OF CONTENTS
Kit Components
Assembly Instructions go to:
https://www.distechautomation.com/p…/pro-v2-hot-end-assembly
KIT COMPONENTS
Prometheus V2 Hot End Components
Machined Parts:
1x: 1-Piece Stainless Steel Nozzle (0.3mm)
1x: 1-Piece Stainless Steel Nozzle (0.4mm)
1x: 1-Piece Stainless Steel Nozzle (0.6mm)
1x: Aluminium Heater Block
1x: Aluminium Heat Sink - with embedded collet
Hardware:
5x: Aluminium Hex Nut
1x: Black (1.75mm) Bowden Collet
1x: Black 4mm ID (1.75mm) Rubber Spacer
1x: 100mm length 2mm ID x 4mm OD (1.75mm) PTFE Tubing (for Heat Sink)
2x: Black 3mm ID Rubber Washer (for Cooling Fan)
2x: M3x16mm Button Head Bolt
1x: M3x4mm Button Head Bolt
4x: M3x3mm Set Screw
1x: M3 Fender Washer
1x: M2 Hex Wrench (for M3 Button Head Bolts)
1x: M1.5 Hex Wrench (for M3 Set Screws)
1x: 100mm Black Zip-Tie
Electronics:
1x: 12V/24V 40W 6mm x 20mm Heater Cartridge
1x: 100KOhm Semitec 104GT2 NTC thermistor
1x: 12V/24V 25x25x10mm Cooling Fan (for Heat Sink)
1x: 80mm length 0.5mm ID 1mm OD High Temp Insulation Tubing (for Thermistor)
1x: 65mm length 2.5mm ID Black 2:1 Heat Shink Tubing (for Thermistor)
4x: 1mm^2 x 12mm Copper Wire Ferrules (Solder-Free Connection)
1x: 1m length Thermistor Wires with 2-pin Dupont Connectors
Opublikowany : 25/11/2018 6:05 pm
thrawn86
(@thrawn86)
Re: Prometheus hot end in a MK 3?
i imagine you'd need to rework the whole assembly to get that heatsink to fit, look how flat and wide it is.
unfortunately this might be a case of di-why?
looking at the product page for this 80$ hot end it seems like get the ability to customize melt zone length...by moving the end of the proprietary nozzle farther away from the heater and adding *hex nuts* to transfer the heat downwards. I guess you also eliminate the junction between heatbreak and nozzle.
Opublikowany : 27/11/2018 3:47 am
Mustrum Ridcully
yes its J head mount will be a simple click in replacement on the Effector plate on the delta when I rebuild it and an extensive redesign of the hotend holding part of the MK3 extruder carriage unless someone has done it and posted the stl files it is lot of work unless I want to make use of those 3 different Stainless steel nozzles it has for abrasive material.
Opublikowany : 27/11/2018 9:34 pm
