Problem with large print, printbed moved
minestoff
(@minestoff)
So I tried printing my 63 hour print, and it failed after 35 hours.
Basically it's a cube 210x210x90 that needs to be strong and in 3 places I need to put screws so that it can be attached. I made the overall infill 20% and around the screws local 100%.
Problem is, around the solid infill it gets all cloggy and uneven, so after a while the extruder bumps into them and it gets worse. And one time it moved the magnetic bed about 10mm which resulted in a layer shift. I noticed it almost immediately and pause the print, moved it back in place and continued the print but it didn't turn out well so then I stopped it.
Any suggestions on how to solve this? Is the problem the local 100% infill?
Other settings: 0,20mm speed MK3s, Prusament PETG,
Posted : 20/02/2020 12:11 pm
Peter M
(@peter-m)
RE: Problem with large print, printbed moved
-With petg use infill honeycomb, search forum for this. Then the nozzle will hit the part less often.
-Do a tower temp test.
-Do a cube test, so you can see that if cube has the size good, so you can see if your not over extruding.
-You could try do less " extrusion multiplier" (see test above).
or do a little lower temperature.(see temp tower test).
-Also check if your extruder, is not loose, wiggle your extruder, tighten bolts.
This post was modified 6 years ago by Peter M
Posted : 23/02/2020 11:59 am
