Printing not straight !!
Victor Martini
(@victor-martini)
Hello,
I have an issue, as you can see on the picture I got a linear offset on Y-axis only.
Do you know where this offset could from ? and what settings or calibration I can do to fix it?
I noticed the heating bed doesn't move smoothly, there is a little resistance when I move it manually.
Thanks.
Napsal : 06/07/2018 1:01 pm
ClassicGOD
(@classicgod)
Re: Printing not straight !!
Verify that the Y axis pulley setscrews are tightened against the motor shaft and one of them is tightened against the flat of the motor. Also check if your belt is tight. After that redo XYZ calibration.
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Napsal : 06/07/2018 2:00 pm
Victor Martini
(@victor-martini)
Thanks !!!!!! , I check what you said and my problem is fixed at 95%
I think now is just optimization.
New line on my monthly maintenance: check pulley setscrews !!
Napsal : 06/07/2018 7:23 pm
