Printing failure after installing 0.6 nozzle
mb
 mb
(@mb-2)
MK3S+ Firmware 3.14.1
Prusament PETG straight from the dryer.
0.6 Nozzle
Recently installed a 0.6 nozzle and appropriate configuration in Prusa  Slicer. Since then, quality has been all over the place.
One of many first layer cal shown here:
Tried a multi square print that looked like this:
Tried a couple of functional prints that looked like this:
I've installed nozzles before by the book, including updating configurations and making the hardware changes, but never had it fail like this.
tl;dr: I can lay down a decent first layer, but I cannot print actual things after a nozzle change. There is no blobbing or leaking. It just seems, at least to me, not be laying down a good first layer on actual prints vs the calibration.
Publié : 22/12/2024 9:29 pm
The built-in calibration routine is only intended for 0.4mm nozzles, you will need to calibrate the 0.6mm nozzle by observation.
Publié : 23/12/2024 2:34 pm
mb
 mb
(@mb-2)
RE: Printing failure after installing 0.6 nozzle
Posted by: @diem
So, help me understand this better....even though I calibrated it and got a decent first layer cal using the internal routine, I need to do it manually for the 0.6 nozzle?
I kinda thought that's what I was doing with the 9 square test, which laid down ok for the most part except for the bottom middle square. I also tried a full sheet square that failed almost immediately.
Publié : 23/12/2024 3:14 pm
Yes, the built-in routine assumes a 4mm nozzle and extrudes accordingly; this is under-extruding for a 6mm nozzle.  Your 9 square is a better choice 'though it looks like you may have some fingerprints on the print sheet.
Publié : 23/12/2024 3:33 pm
Robin
(@robin)
What diem said used to be true, but since firmware 3.13 the internal first layer calibration works with different nozzle diameters:
https://help.prusa3d.com/article/different-nozzle-types_2193#first-layer-calibration-of-other-nozzles
Publié : 23/12/2024 4:45 pm
Thanks for the correction, I've only used 0.4mm nozzles on the Mk3 in the last year and hadn't noticed...
So what I wrote above only applies if you haven't changed      Settings -> HW setup -> Nozzle
Publié : 23/12/2024 7:59 pm
