Print partly "shifted" to the right - Collision?
The Grue
(@the-grue)
Hello,
I have a model that prints quite well, until almost the end is reached. Then, there's suddenly a kink, it looks like the whole print is suddenly shifted: usually only a few 100 μm, and usually in Y direction.
Yesterday I printed it again, and it was shifted several cm to the right! There's some problem with my printer, it seems... All the belts have good tension, the shafts are lubricated and I see no reason for a collision - but I am only a rookie. Could you help me with that problem, please?
I attached the model and here are some images of the problem.
Large error, X-Direction
Right after the print with the large error, the printer's statistics said:
Last Print:
Network error: 0
Filament Error: 3
Crash X:5 Y:0
Overall:
Network error 1
Filament error: 3
Crash X:6 Y:7
With smaller prints, I never notice such errors. The Printer is self-assembled, about one year ago. It has about 4 days of printing time, according to the statistics.
Thank you very much for your help!
Attachment removed
This topic was modified 5 years ago by The Grue
Posted : 16/05/2021 5:40 pm
RE: Print partly "shifted" to the right - Collision?
@the-grue
I'd make an initial guess the X-axis has too much friction. Dry bearings or a clamp that's too tight causing bearings to seize.
ps: That said - the part is large, and large parts have a tendency to lift off the bed as they warp. The lift may be causing the nozzle to snag as it travels. You might try increasing the bed temp to 75c to help it keep the PLA down. Or add brim like ears to the corners in addition to a higher bed temp.
This post was modified 5 years ago 2 times by --
Posted : 16/05/2021 5:50 pm
Ran out of time to edit -- lol.  The shift mid print hints the issue is always there, not just at the top of the print. While axis shift due to part warp and lifting is pretty common as parts extend to the sides of the 250 mm platter and higher print temps help: shifts down lower are usually drag induced. My last 240mm wide PLA print required 75c to hold it down.  I usually adjust the bed temp only after after many layers are down.
Posted : 16/05/2021 6:00 pm
Swiss_Cheese
(@swiss_cheese)
@the-grue
I couldn't help but notice the wires for the extruder stepper are hang out for all the world to see, you may want to tighten that up a bit. is it possible it bumping or getting caught on something at times ?
The lower shift could possibly be from cooling and the part warping slightly before the print head gets back to it for another pass.
Just speculating,
Swiss_Cheese
The Filament Whisperer
Posted : 17/05/2021 3:38 am
That is definitely a layer shift and is nearly always a mechanical issue on the axis involved.  This is an X-axis shift.
Check your bearings, grub screws, and belts.
Posted : 17/05/2021 6:39 pm
The Grue
(@the-grue)
Thanks for all your ideas! I'll check everything and cross my fingers...
Which is more likely: a belt that is too loose or too tight? If I pluck it like a guitar string, I hear a wave, so I guess it not too loose...
Posted : 18/05/2021 3:48 pm
@the-grue
I've had my belts so tight I probably damaged the motor bearings - had to use leverage to get them on. So your shifts are not belt tension related. Axis must move easily, freely, and without any stiction. Gravity should be enough to move the extruder side to side and bed back and forth.
This post was modified 5 years ago by --
Posted : 18/05/2021 4:50 pm
@tim-2
Thanks.  I have never heard it put that way but I will test mine that way from now on.  Mine might be too tight.
Posted : 18/05/2021 5:13 pm
The Grue
(@the-grue)
How can I influence this if it is not belt tension related?
My Y axis moved by gravity, the X axis doesn't...
Posted : 18/05/2021 5:38 pm
The Grue
(@the-grue)
I was wrong, the extruder moves on the X axis by gravity.
BTW: I can't find a way to delete a message. Do I miss something?
Posted : 18/05/2021 6:04 pm
@the-grue
There is no delete after a few minutes.
Loosen the case screws on the back of the extruder - the ones closest to the bearings. You want them attached, very lightly snugged so they don't rattle.  With he screws loosened, see if the issue goes away.  Sometimes the screws being too tight will bind the bearings causing them to seize on the rods.
If this solved the issue - tighten the screws - but don't reef them down - then back them off a half turn or so. Each printer is different.
Posted : 18/05/2021 6:09 pm
Posted by: @tim-2
@the-grue
That is somewhat annoying but it to prevent forum destruction.
@The Grue
Sounds like it is not the belts.  Have you checked all of your gears and grub screws?
Posted : 18/05/2021 6:41 pm
The Grue
(@the-grue)
@cwbullet
That's a bit complicated for the X axis... I'll disassemble the parts on the weekend and have a close look.
Posted : 18/05/2021 6:58 pm
@the-grue
Ok.  I would check everything and rebuild following the directions very closely.
Muscle memory might be your enemy.
Posted : 18/05/2021 7:00 pm
