Preventative Maintenance Schedule
(@09929381)
All,
My company has been running a print farm for several years. We are retiring our Lulzbot Taz printers. They have been very labor intensive and unreliable for 24/7 printing. Side note: never use Lulzbot printers for industrial scale printing. You will have a bad (and expensive) time.
We have been directed to Prusa for the quality, support, and reliability of its printers.
Does anyone have a preventative maintenance schedule for this printer?
Use: 24/7 intricate parts using PLA exclusively
I am creating a list for our operators to replace parts on a scheduled basis and to check for failure.
For example:
How often to check for bed leveling?
Are there fasteners prone to loosening?
How often should the nozzle and heat brake be replaced (using PLA ~210-220C)?
Do any sensors wear?
Anything else I am missing? What are common things to look for on a monthly basis?
Questa discussione è stata modificata 4 years fa da 09929381
Postato : 05/02/2022 3:03 pm
Utenti
RE: Preventative Maintenance Schedule
I have not checked it in 3 years.  It pretty much checks itself.
I check the terminals once a month on the power source.  I check the other screws every 2-3 months.  They rarely loosen.
Unless I print abrasives, they last up to a year (or more).  I have never replaced a heartbreak.
Thermistors will need replaced sometimes.  I have had to replace them about one a year or so but I have some that are 3 years old.  I clean the bed one to two times a week.
Once every 1-3 months, I add a little lubrication to the bearings if it seems like it needs it.  It increases with age.
Posted by: @09929381
All,
For example:
Postato : 15/02/2022 1:06 am
Stefan
(@stefan-3)
  • Lubricate the smooth rods in shorter intervals, but with very little amount of grease
  • DO NOT lubricate the thread of the Z-axis, as the nut is made of a self-lubricating polymer
  • Lubricate the Bondtech gears with very little grease (not the groove for the filament)
  • Clean the blades of the fans from dust and stringing (if you print PETG). Block the rotation of the fan if you use a vacuum cleaner, so that it does not spin with 100000 RPM 😉
Postato : 15/02/2022 5:55 pm
npnp405
(@npnp405)
I have a google sheets I use as a reminder.  Here it is, I can add a link to it if you would like.  The cells change color based of of how late or early you were to doing the maintenance.
Postato : 11/04/2022 2:01 am
Marius C.
(@marius-c)
Utenti
This is how we do it and it worked very well :
Postato : 21/01/2023 1:15 am
