PREHEAT ERROR
thomas.s10
(@thomas-s10)
PREHEAT ERROR
The bed temperature comes up to 60 and holds.
When the Extruder temperature reaches 170 the heating process shuts down. I get a PREHEAT ERROR.
I’ve checked all the cables and they are in the correct locations.
The temperature reads fine in the display , until it reaches 170, then the target temperatures go to zero
and the Display reads the temperatures until they reach room temperature.
Ce sujet a été modifié il y a 6 years 2 fois par thomas.s10
Publié : 12/08/2019 12:00 pm
RE: PREHEAT ERROR
Sounds suspiciously like a bad thermistor: they heat up then fail open; hence temps rise then at some point drops to zero.  And, the failure is intermittent: when it cools down, everything is fine again.  But a closer inspection will usually reveal the 25c resistance is not correct.
Anyway - order a new thermistor from Prusa ... that way you get the proper cable length and termination. Or order from E3D, but you'll probably need to adjust lengths and connector.
Publié : 12/08/2019 5:55 pm
1 personnes ont aimé
RE: PREHEAT ERROR
Try PID calibration; if the issue persists then do the same thermistor tests.
Publié : 09/09/2019 2:02 pm
