Power failure
drb1515
(@drb1515)
Power failure
so i have two identical MK3S printers with the same firmware. But when there is a power failure one printer resumes perfectly and the other is wayyyy out of aligned, the Z axis is fine but the Y is easily around ½" out.... Any thoughts? I should have taken pics but I did not.
Opublikowany : 29/09/2022 3:41 pm
Robin
(@robin)
RE: Power failure
Do you have a cat? And if so, does the cat have access to where your printers are?
Opublikowany : 29/09/2022 4:02 pm
drb1515
(@drb1515)
RE: Power failure
So right after i wrote this it dawned on me to check what could be "wrong" with the Y axis and it was banging on the enclosure not allowing it to go fully back. Which is strange because it does the bed calibration just fine. But anyway i moved the printer away from the enclosure wall and just test the power panis and it went perfectly.
Opublikowany : 29/09/2022 4:12 pm
