Powder Coated Sheet Shipping with MK3S?
Hello all,
I’m glad to see that the powder coated PEI sheets are finally making it on to the Eshop for current owners, but is there any estimate for when the sheets will be available to order with the MK3S kit? I’ve been holding off buying an i3 until I can get it with the powder coated option.
Thanks!
RE: Powder Coated Sheet Shipping with MK3S?
No announcement, but suspect once they are widely available.
If I were you, I would just buy the printer and then pick up the powder coated sheet later... cant hurt to have an extra sheet anyway.
^^^^This^^^^^
Looks like you could easily order both this morning. The long cold night is ending, a new textured morning is beginning.
No reason to hoard at the moment.
I understand the importance of spares, but if I can get away with one bed, I think I'd prefer the powder coated, especially given the increase in price.
I plan to order in a few weeks, so if the MK3S is still sold exclusively with the PEI sticker sheet, I'll probably do what you suggest: order it and then order the powder coated sheet later (or along with it).
Thanks for the input everyone!
The PEI sticker sheets are more robust and work with a more diverse group of filaments in my opinion, but TXT PC sheet works with some filaments better. Also, the TXT sheet provides texture vs the smooth surface of the of the PEI Sticker sheet.
Can you provide link to the page, please? For the life of me, I can't even find it.
Erik
... Also, the TXT sheet provides texture vs the smooth surface of the of the PEI Sticker sheet.
Depending on the aesthetic demands of individual prints the texture may be a good or a bad thing... Best to have (at least) one of each type of sheet.
See my (limited) designs on:
Erik
You have to login
I'am login but i don't find this one !
Prusa Core One - Prusa MK4S -2x Prusa Mini+ - Bambulab X1 Carbon/P1P- Silhouette Cameo 4-Laser Xtool S1 40w- Imprimante Canon Sublimation...
Just ordered one, looks like they are back again.
https://shop.prusa3d.com/en/mk3mk3s/214-powder-coated-spring-steel-sheet.html
You will find it under spare parts
But if you haven't bought a printer from Prusa I don't think you can access it
Out of stock again: https://shop.prusa3d.com/en/mk3mk3s/214-powder-coated-spring-steel-sheet.html
I also confirmed that search works: https://shop.prusa3d.com/en/search?controller=search&orderby=position&orderway=desc&search_query=powder+coated&submit_search=
You have to login
Thanks, that was the trick!
I was going insane knowing I had visited the page in the past and monitored whether or not they were in stock. But it must’ve been while I was logged in to check on delivery of other things. It would help if there were some indication that there’s more to the site if you’ve already purchased a printer.
Thanks again!!
Erik
