Powder Coated PEI Sheet
MakerDAD
(@makerdad)
Hello, i don't see any reference regarding the "Powder Coated PEI Sheet" on the Prusa website or shop, nowhere to order it or even select it with a new MK3s, does this mean that it will no longer be available with the MK3s or by itself? Thanks.
Napsal : 19/07/2019 12:36 am
C-TECH
(@c-tech)
RE: Powder Coated PEI Sheet
Have you checked the store again. I just opened the online store and I had an option with the MK3S Kit to add a Powder coated sheet, a smooth sheet or both to my order.
If you have already purchased a printer from Prusa you can log into your account on the web store and in the Parts section for the printers you will find the replacement sheets (both Smooth and Powder Coated). If you still have troubles I would recommend talking to the Prusa staff in the online chat.
Napsal : 19/07/2019 3:04 am
lindharin
(@lindharin)
Just to reiterate: make sure you are logged in to the web store first.  Most parts will not show up if you are not logged in, as I discovered earlier tonight when I was looking for TPFE tube replacements.  I think there were only 6 parts visible prior to logging in, and dozens afterwards.
Napsal : 19/07/2019 4:15 am
MakerDAD
(@makerdad)
Yea, that was it, it wasn't showing because i wasn't logged in, once i logged in the option appeared, thanks.
Napsal : 19/07/2019 4:42 am
