postprocessing of prints - recommended rotary tools for polishing
SteadyEddie
(@steadyeddie)
Hi All,
As a newbie, I have read through https://blog.prusaprinters.org/postprocessing-of-3d-prints-step-by-step_29270/ to get a feeling for post processing. Now I would like to get my hands on suitable tool for polishing in addition to the recommendations on that link.
Does some-one have any recommendations for a suitable rotary tool for polishing purposes?
Thanks!
SteadyEddie
Opublikowany : 24/08/2021 8:28 am
I use
I use this Dremel brand tool.  I prefer it because it is battery-powered.  I have cheaper ones but none are quite as well-engineered.
Opublikowany : 24/08/2021 9:46 am
1 ludzie polubili
SteadyEddie
(@steadyeddie)
thanks for this. Looks a good choice.
Would an electric cable powered Dremel would be overkill for such polishing applications? Im also thinking about battery life depletion over time for battery powered.....?
Opublikowany : 24/08/2021 9:57 am
The trap to avoid is over-powerful tools that generate so much heat as they work that they remelt the plastic.  You can do alot with hand tools: needle files and sanding sticks...  Wet and dry abrasives used wet are especially useful.
I too use a small Dremel type drill/sander where necessary but more often with a cutting tool than a buffer - but I make mostly functional parts so I'm not so worried about finish.
Opublikowany : 24/08/2021 11:08 am
1 ludzie polubili
jsw
 jsw
(@jsw)
Posted by: @steadyeddie
I think I mentioned this before.
My 'Dremel' is actually a Sears Craftsman branded unit which runs off of AC.  It's about the same size and same apparent power as the battery-powered ones.  I use it mostly as a small drill for model railroad type work.
Opublikowany : 25/08/2021 10:59 am
