Possible to turn off filament sensor in gcode?
Bas
 Bas
(@bas-2)
Is it possible to tell the printer to turn off the filament sensor for a certain print? I have some translucent filament that the filament sensor trips out on, and I'd like to create a filament profile for it in slic3r that automatically turns the sensor off for that print, so that I don't have to do it manually in the menu.
Opublikowany : 15/05/2018 9:02 am
Gato
 Gato
(@gato)
Re: Possible to turn off filament sensor in gcode?
Looking at https://github.com/prusa3d/Prusa-Firmware/blob/MK2/Firmware/Marlin_main.cpp . Seems to be M406 (Turn off filament sensor for control )
Opublikowany : 15/05/2018 9:09 am
Bas
 Bas
(@bas-2)
Awesome, thanks for the pointer!
I notice there's also gcode for turning the sensor back on, with a "delay in centimeters" between sensor and extruder. Anyone know if that one is supposed to be set, and if so, at what value? I can't find it being used anywhere in the firmware.
Opublikowany : 15/05/2018 10:31 am
Bas
 Bas
(@bas-2)
Huh, weird, it doesn't seem to be doing anything. I noticed that the gcode has my filament-specific code in there, but I don't see any message and the sensor remains on. I don't even see the M117 message. Any ideas?
G92 E0.0
M221 S95
M900 K30; Filament gcode
M406 ; Disable filament sensor
M117 Filament sensor UIT
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
;BEFORE_LAYER_CHANGE
Opublikowany : 15/05/2018 12:37 pm
Zarsk
(@zarsk)
I found that after i installed a filter with a sponge blocking light from getting into the filter feed are that the sensor works much better even with some translucent materiel i have.
Opublikowany : 15/05/2018 3:33 pm
Bas
 Bas
(@bas-2)
So, it turns out that M406 is not implemented in Marlin yet. Alas! Not sure why the M117 code isn't working either, though.
Opublikowany : 16/05/2018 10:24 am
Erwan
(@erwan-2)
I have transparent CPE that triggers false positive all the time, I would love to have a check box to deactivate the filament sensor in the filament settings of Slic3r PE!
Opublikowany : 16/07/2018 12:41 am
Area51
(@area51)
You can report it as a feature request or error on GitHub https://github.com/prusa3d/Prusa-Firmware/issues?q=is%3Aopen . The developers will see it there.
Opublikowany : 16/07/2018 12:36 pm
