Pooling BVOH Filament
I have a Prusa i3 MK3S with the MMU2S setup. I use the PrusaSlicer program to generate the G-code. When I start my print, the first layer is fed by the #1 feeder of the MMU and is loaded with PLA Prusament filament. Everything works fine until......it now needs to print the soluble layer. The MMU will unload the PLA, and then switch to the #4 feeder to load the Verbatim BVOH water soluble material with no problem. When the material is loaded down to the extruder, it just pools up on the build plate purge area without moving the head. Any ideas of what is wrong? If I load another spool of PLA in slot #4, everything works fine.
Veröffentlicht : 18/09/2019 12:49 pm
