PLA stringing
B3DS
 B3DS
(@b3ds)
PLA stringing
Hi guys,
Have printed a few things now since I got my mk3 a few weeks back. I'm in the process of printing the Endeavour that is available on thingiverse.
https://www.thingiverse.com/thing:478422
It's not a huge print but I've noticed some very fine stringing between some of the finer details. Ie. Ropes. I want to tweak the retract settings slightly... probably retract distance. I havent really been able to find any thing. Anyone out there got any suggestions?
Thanks
Opublikowany : 25/05/2018 2:52 pm
DevDoc
(@devdoc)
Re: PLA stringing
Try lowering the temp a few degrees or increasing retraction slightly. That most likely will take care of it for you. The temp should be the first try perhaps 5 degrees lower so long as you are not below the recommendation of the manufacturer or hear skipping.
Opublikowany : 25/05/2018 3:11 pm
thrawn86
(@thrawn86)
Re: PLA stringing
Thanks
print a bunch of these and try out different settings: https://www.thingiverse.com/thing:22263
I usually end up around 1-1.5mm retraction at 40-50mms with around .5 or .6 hop.
Opublikowany : 26/05/2018 4:15 am
