PINDA bracket
Where is the PINDA sensor bracket listed as a spare part for the PRUSA i3MK3S? I can't find it, its a fragile little bit of crap that has broken on mine
Opublikowany : 24/12/2021 4:06 pm
RE: PINDA bracket
You won't find it as a spare part by itself because it's integrated into the extruder body. If you order it, be sure to select the model correct for your MK3S because it's different from the extruder body of the MK3 or the MK3S+
https://www.prusa3d.com/product/extruder-body-bl-mk3s-mmu2s-mk2-5s/
Opublikowany : 24/12/2021 10:03 pm
