PETG V0 printing Dificulties
Helder112
(@helder112)
Hello All,
Hope you can help me, I buy from prusament PETG V0 filament but since first print I have issues, noozle leak filament and even at 220º.
I try to do a temp tower and this is the result:
Can you help me on your expirience with this filament and what could I do to improve this?
Tommorow I will de a flow test and will try to find a good test for retraction.
For what I can see any of these temperatures are good. what is you opinion?
thank you all for your help.
Best regards
Helder
Posted : 18/12/2023 11:14 pm
RE: PETG V0 printing Dificulties
when the print ran, did the temperature actually change?
I have had temperature towers that didn't change, which gave similar results
Joan
Posted : 19/12/2023 12:10 am
Helder112
(@helder112)
Thank you for your feedback, I double checked the Gcode and it does change the temperature. also we can confir that by the picture where in 260º the color are more silk than lower ones.
This post was modified 2 years ago by Helder112
Posted : 19/12/2023 10:12 am
JochemB
(@jochemb)
Did you ever solve this? I'm now running into this issue and have been trying adjusting retraction (up to 2 mm), lowering the temperature, changing the nozzle, etc. But it keeps stringing like this!
Posted : 29/07/2025 7:47 am
