PETG settings in PrusaSlicer-2.2.0
DHenss
(@dhenss)
I have been working on dialing in my MK3S to print PETG.  I have found a lot of information floating around.  The first thing I notice is that a temp tower ( https://www.prusaprinters.org/prints/20652-temp-tower-pla-petg-abs-mmu2s-compatible ) should be printed to see where your filament works the best.  In my case I am using MatterHacker PETG and found that first layer should be set to 230 and all other layers set to 220.
Where I am running into trouble is where to put some of the other settings I have found that help with PETG.
Some of the settings that I would like to adjust are:
Retraction Length
Retraction Speed
Lift Z
I see these settings in the Filament Setting tab and the Printer Settings tab.  Which tab should I be using to enter the settings I want to adjust, or should be I be using both tabs and entering the same data.
Any comments or suggestions?
Thanks
Publié : 03/08/2020 1:35 pm
Peter M
(@peter-m)
RE: PETG settings in PrusaSlicer-2.2.0
I think the printer settings.
Publié : 03/08/2020 7:39 pm
Holck
(@holck)
The filament setting under filament override will overrule the printer setting, so if you want this to happen for this PETG filament only, put it on the filament preset
Publié : 03/08/2020 8:14 pm
