PETG rough top layer
I've set the z-axis and it is fine.
The top layer of a print is rough. It a simple flat print.
Temps :
Nozzle: 240C
Plate: 85C to 90C
Opublikowany : 24/09/2025 7:53 pm
RE: PETG rough top layer
How thick of a flat print? Is 240 correct for your filament? I have a PETG that 240 is the maximum temperature recommended.
Opublikowany : 01/12/2025 7:02 pm
Check the pictures here
https://github.com/OrcaSlicer/OrcaSlicer/wiki/flow-rate-calib
at 4) Examine the blocks and determine which one has the smoothest top surface.
Does any of this look familiar? I suspect overextrusion.
Opublikowany : 01/12/2025 7:07 pm
Being a Prusa printer, I just use their suggestion for extrusion rate.
Opublikowany : 01/12/2025 10:27 pm
