PEI Protection
clint.g
(@clint-g)
PEI Protection
Newbie question ... but I haven't seen it mentioned anywhere ...
Do people protect their heatbed / PEI sheet while working on the extruder?
I'm having nightmares about an errant Allen key augering a divot in the surface.
Just a board laid over the heatbed? But then we're increasing the possibility of an extruder crash into the very thing designed to protect the heatbed ...
-- Clint Goss
Postato : 15/04/2018 9:08 am
Peter L
(@peter-l)
Re: PEI Protection
The PEI is pretty tough. You're not going to damage it by just dropping a tool or part on it.
To damage the PEI you'll need to do something like gouge it with a knife blade.
Postato : 15/04/2018 10:33 pm
Re: PEI Protection
I take my spring steel sheet off... and put it somewhere safe
Postato : 15/04/2018 11:12 pm
digibluh
(@digibluh)
Re: PEI Protection
i would rather something damage the PEI sheet than the actual bed that heats up... there are traces under there and could get damaged accidentally. usually printers have glass over them. i would rather the steel sheet... it's not powder coated anyway so... no biggie if the PEI gets damaged.
Postato : 16/04/2018 7:15 am
Kwaad2
(@kwaad2)
Re: PEI Protection
And for 108.85$ I can get a new heatbed delivered to my door, in sub-1-week.
For ~840$ I can get a PEI steel sheet delivered to my door in about 1 month.
Personally. I think the heatbed is much cheaper. Although honestly, the new PEI sheet comes with a few spare parts...
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Postato : 16/04/2018 9:55 pm
Nikolai
(@nikolai)
Re: PEI Protection
I don't really understand this question. It's common sense to protect something valuable.
Like a table where you do your assembly or a hand/fingers while you attach or remove parts from the printer or ...
If you worry about the heat bed while working above, just place a hand towel over it.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 17/04/2018 1:13 am
